 Post subject: RAID 0 Repair
PostPosted: August 12th, 2007, 13:28
I have an Intel-based RAID 0 as an integral part of a Dell PC. One of the drives developed bad sectors. I was able to image the drive and recover the data. However, when I put the imaged drive in the PC, the system reports that is not a member of the RAID.
How can I "add" or "join" the repaired drive to the RAID? (I also have the Intel RAID Matrix Utility).
Thanks in advance.
Jon
http://www.datasaversllc.com
 Post subject: Re: RAID 0 Repair
PostPosted: August 13th, 2007, 0:07
Use Winhex to rebuild array in memory , recover data , then rebuild array with your raid utility.
PS .. Howdy neighbor , I'm down the road in birmingham
PostPosted: August 13th, 2007, 1:11
Hi neighbor,
Thanks for the quick and helpful answer.
I'm a "hardware" guy . . . . and I'm not sure how to use Winhex as you describe. Can you point to any downloadable resources that might offer a bit more detail?
Thanks & best regards,
Jon
PostPosted: August 13th, 2007, 1:28
http://www.x-ways.net/winhex/winhex.pdf
basically you click on specialist menu , click assemble raid system
then another menu opens , you select the drives in the raid , select the raid type ( 0 in this case ) then click ok ..
it will open another window which will be the full array , there will be
a drop down that says Access, click the arrow , and click open partition.. then wait for it to do it's magic :)
and of course you know NEVER NEVER write to the drives you are trying to recover :mrgreen:
Also Runtime's Raid reconstructor works well also , but you have to
copy the entire raid to another drive ( or image ) then do the recovery on that .
Almost forgot ..R-Studio works well also
btw .. you work in a dr shop, or just a computer shop?
PostPosted: August 13th, 2007, 18:03
Steve,
Thank you for your helpful & very generous response. I'll check out the link and see if I can figure it out.
I used to own a PC shop from 1986 - 1999. We specialized in Macs and had a client base of about 6,000. i sold the business and now do DR almost exclusively.
My own specialty is component-level repair, so PC board fixes are pretty standard. I'm working on some tools for DR that I hope to have prototyped soon.
I am assembling a pretty good library of HDU firmware and SA resources. Let me know if you need anything, or PM me if you'd like me to give you a call. Allies are very hard to find in this business . . . .
Jon
Users browsing this forum: No registered users and 65 guests
