 Post subject: maxtor calypso 6y60l0 translator reg
PostPosted: August 13th, 2007, 1:16
hello i have hdd maxtor 6y60l0 it was with z letter and no serial i loaded using ldr file the sa checksum every thing gives uba error i wrote modules its ok and z letter gone serial is ok but still p list error and glist error also some modules still bad even i rewrite them again when i try to regenrate translator in normal mode it gives errors when reading p list so what to do?
 Post subject: Re: maxtor calypso 6y60l0 translator reg
PostPosted: August 14th, 2007, 7:18
What does the SA write test give when u load an LDR ?
PostPosted: August 14th, 2007, 13:50
Banned User
if plist and glist are not ok, then hdd will show bad fw and z letter,
u load correct ldr and then go to the option SA WRITE TEST, if it is zero, then u can write easily
Users browsing this forum: Google [Bot] and 74 guests
