 Post subject: Toshiba problem
PostPosted: August 4th, 2007, 13:49
I have a problem with 2.5 toshiba hdd the problem is when i connect it to a ide convertor in my pc with victoria there is no power in the hdd and it reports readiness DRDY and DSC i cannot hear any motor spinning nor any heads parking , on pressing F4 it does not show id and give ABRT error .
Is this a FW problem or pcb .
Thanks .
 Post subject: Re: Toshiba problem
PostPosted: August 5th, 2007, 14:22
The heads are probably parked over the platter, preventing start-up.
Open the HDA and return the head stack to its normal position.
Jono
http://www.datasaversllc.com
PostPosted: August 6th, 2007, 3:54
When you apply power, listen carefully. Can you hear a quiet "buzz buzz sound"?
If so, then jono-ats is correct :-)
PostPosted: August 7th, 2007, 0:08
Try to check if its a PCB problem, if no maybe u have spindle problems, most common on toshiba,
Best Regards
PostPosted: August 9th, 2007, 13:43
Hi Rameez,
Did you solve this man .I was interested to know the results .Sorry been busy for 2 /3 days
PostPosted: August 11th, 2007, 13:42
thankyou , for all your replys i checked pcb its not working on other hdd so i think its a pcb problem but i dont understand one thing why the hdd report readines if the pcb is not working .
What do u think would be the problem with the pcb like which component ?
PostPosted: August 15th, 2007, 7:49
Have you tested the fuze with a multimeter? This is quite a common failure in Toshiba PCB
PostPosted: August 17th, 2007, 3:49
yes not a fuse problem anything else u could advice .
thanks
PostPosted: August 18th, 2007, 11:50
most of toshiba problem come from head stucking and motor problem.
It's not so hard to make some DR from this problem.
there are a lot of information in this great forum shows you how to make a DR from this kind of problem.
enjoy.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 144 guests
