 Post subject: old pc with new hard drive !
PostPosted: July 27th, 2007, 2:20
hi !, I have an old pc which can only detect old hard drive and it only run on chs no lba. I've got an 60gb hard drive but the pc can only detect hard drive size of 540mb ... i doesn't need the pc to detect the all the space, i just want the pc to work :D
 Post subject: Re: old pc with new hard drive !
PostPosted: July 27th, 2007, 2:29
Please post configuration of your Computer.
DF
DF :)
www.datatracksystem.net
PostPosted: July 27th, 2007, 3:46
hi dark! thanks for the response :D
the pc it self is running on dos 6.22
and running on 50mhz (Motorola processor)
and it's using adaptec ide controller which there listed to support chs configuration as follow
1023 63 255
1053 63 255
i've try use another pc to format the hard drive with the following chs but the old pc fails to detect it !
PostPosted: July 27th, 2007, 4:08
Sorry but I think nothing could be done on this system. need to update the system.
DF
DF :)
PostPosted: July 28th, 2007, 3:26
try MHDD tp cut its Size to lowest size that can be detected in OLD PC.
use HPA Command. I think it can help you...
Спасибо
СУТИОНО / АПИНГ
PostPosted: July 28th, 2007, 13:01
throw the pc away no use of this pc .
PostPosted: July 28th, 2007, 21:22
hi guys !,
prodata : thanks, will try use MHDD and see whether it works or not :)
- i wish too change the system, but the job done by the old pc are running on a dos platform that the problem :D
and their IO card are ISA ! hehe if only i can put in a intel 266mmx :) hehehe
PostPosted: August 6th, 2007, 3:27
I've try MHDD with the HPA function, unfortunately i always get the HPA fails.
I'm using a maxtor hdd which manufacture by Seagate and the model are STM960212A
PostPosted: August 9th, 2007, 13:45
Hi Xf86 ,
I will help .Tell Me More Details of Your System.I have old Pc in my office nearly everyday .I will try to help you 100%
PostPosted: August 12th, 2007, 2:23
HI
for old PC-s i use CompactFlash2IDE adapter and 256-512MB CF cards.
PostPosted: August 15th, 2007, 4:48
yeah i've thought of the CFtoIDE ... but my place it's hard to get it :)
neway ... the pc i'm running on ... it's actually running on a propriety system.
which is using dual Motorola's 50mhz processor and the ide controller are using adaptec and
it have written to support chs mode - 1053 16 63 or 1024 16 63.
PostPosted: August 15th, 2007, 11:52
i've just try the MHDD with my Celeron system running on P945 chipset and i'm using a 44 pin to 40 pin converter to connect my 2.5inch Fujitsu 40gb hard drive to my pc and when i do HPA and it said fail to set HPA
please power off drive and try again. I've got the same message with my 2.5inch Maxtor 60gb hard drive.
I'm using the PTcalc ... to generate the LBA value.
Users browsing this forum: Google [Bot] and 72 guests
