 Post subject: Is data recoverable after wiping?
PostPosted: August 14th, 2007, 2:29
Hi pals, I'm not sure if this should be here or somewhere else but I would like to find out answers and I hope you can help.
If a hdd had been wiped with hdd wipe tool, is data recovery possible at all? What I understand is every byte had been re-initiated (set to zero) when wiped, am I correct? Can computer forensic be able to recover data after this process?
 Post subject: Re: Is data recoverable after wiping?
PostPosted: August 14th, 2007, 7:04
no not possible .
PostPosted: August 17th, 2007, 4:53
Thanks, I would like more replies to substantiate the claim because I've heard from a few sources claiming that computer forensic is able to recover data after a hdd was wiped. This is quite a dilemma.
PostPosted: August 19th, 2007, 15:40
You may try to search this forum, it's been discussed a number of times. It is impossible to recover data after a hard drive has been erased.
Dmitry
PostPosted: August 24th, 2007, 9:38
I agree, nothing can get your data back.
Dobre
Murphy was an optimist
PostPosted: September 27th, 2007, 8:15
Banned User
well if only few percent wiped then can be recovered 90%...
if u wiped all over with strong tools like pc3000 and salvation then not possible..
SPAM removed by admin. Beware: Diskanalyzers (diskanalyzers.com) is SCAM/FRAUD web site! They also spam forums!
PostPosted: January 20th, 2008, 23:39
if you wrote "0"s to the drive the only recoverable data might come from erasing G-list and using winhex ect to read the sectors that were skipped in the re-write
I think ST is a sub company of Lucas
