 Post subject: Safe mode
PostPosted: July 2nd, 2006, 11:09
Hy all people !!
Does anyone Know Safe mode setting for a SATA Maxtor Calypso 6Y120M02371BA
Thanks for all
 Post subject:
PostPosted: September 16th, 2006, 6:35
See the maxtor safe mode confiquration on the pc3kisa manual
 Post subject:
PostPosted: September 17th, 2006, 4:32
SATA safe mode confiquration is not present in the manual why dont u give it on the forum
 Post subject: Re: Safe mode
PostPosted: August 6th, 2007, 8:34
another unanswered question
PostPosted: August 6th, 2007, 9:18
In UDMA version ACE is providing terminal for Maxtor Calypso.
DF
DF :)
www.datatracksystem.net
PostPosted: August 6th, 2007, 9:39
Yes, it supplies 5v to a pin on the drive.
It's possible to make yourself too. ;-)
PostPosted: August 6th, 2007, 9:41
pcimage, how to make one up?
PostPosted: August 6th, 2007, 10:22
You have PM.
PostPosted: August 7th, 2007, 0:26
Think you could send me the info too? Thanks!
PostPosted: August 7th, 2007, 9:57
PostPosted: August 7th, 2007, 23:37
Starling, the safe mode does not work with Diamondmax plus 9 SATA model 6Y160M004721A
PostPosted: August 8th, 2007, 9:32
Yes it does ;-)
I just tried it :-)
BTW, I made a mistake. The 5v to pin solution is for Sabre SATA, not Calypso. The one Starling states correctly is for Calypso.
PostPosted: August 10th, 2007, 15:47
wat can be done to the drive when it is in safe mode?
PostPosted: August 10th, 2007, 16:26
u can fix firmware problems etc.
But u DO need proper tools (i.e. PC3000, Salvation etc)
PostPosted: August 11th, 2007, 14:07
also it is used for fixing hdd with bad head for eg clicking drives .
PostPosted: August 23rd, 2007, 21:55
Is safe mode also called PCB mode?
PostPosted: August 24th, 2007, 4:19
yep, in WD it is (Salvation products) (or "kernel" mode in PC3000)
PostPosted: August 24th, 2007, 7:39
So you can make ROM changes in safe mode, but you can't make FW changes since FW changes involve writing to the SA and heads are disabled in safe mode. Is this correct?
Sorry about turning the topic slightly.
Thanks,
Andy
Users browsing this forum: Google [Bot] and 70 guests
