 Post subject: Fujitsu MHV2080AH burnt processor any chance?
PostPosted: August 30th, 2007, 1:01
HI gurus!
I have Fujitsu MHV2080AH with burnt main processor any chance of recovery? The main processor is BGA type.
Thank's
 Post subject: Re: Fujitsu MHV2080AH burnt processor any chance?
PostPosted: August 30th, 2007, 3:58
Does the drive have ROM?
PostPosted: August 30th, 2007, 6:14
no, ROM is embedded in microprocesssor " i think", maybe someone can confirm
PostPosted: August 30th, 2007, 11:37
you will be amazed at how compatible MHV pcb can be.
Just try some.. :wink:
PostPosted: August 30th, 2007, 11:41
coffeebean...you mean any mhv pcb with same firmware will work?
PostPosted: August 30th, 2007, 11:43
I got the same oppinion as coffeebean.
I've managed to recover some this way.
PostPosted: August 31st, 2007, 4:51
i have exact same firmware and i swapped over, not working still clicking.....could it be hda bad?
PostPosted: August 31st, 2007, 5:44
Hi Jose
I tried with same fw still clicking, i think the Head preamp is faulty too...
PostPosted: August 31st, 2007, 9:10
MHV - heads very sensitive.
be cautious when transplanting new heads not to "stretch" spring arms
when opening heads for insert to "ramp".
Also, these heads pick up tiny particles very, very easy and then collect
more from media.
Just check heads with microscope, if some "dirt" almost can forget it for success.
Also check profile of head surface and you can see why these heads are good at
scratching media surface.
PostPosted: August 31st, 2007, 22:18
thanks for the tips coffeebean
PostPosted: September 2nd, 2007, 23:38
Is this flash ROM?
PostPosted: September 4th, 2007, 0:06
No, thats a diode. If the processor failed i am afraid it's gone, firmware on MHV cannot be matched just from the label itself. sometimes it does not work.
PostPosted: September 5th, 2007, 3:42
any other ideas gurus? :(
Users browsing this forum: Google [Bot] and 78 guests
