 Post subject: Seagate ST340014A PCB compatibility?
PostPosted: September 5th, 2007, 18:10
What values (Model, P/N, HDA P/N, Configuration, Firmware, Date Code, Site Code) do I have to match in order to switch the PCB from one Seagate ST340014A drive to another?
TIA,
Phil
 Post subject: Re: Seagate ST340014A PCB compatibility?
PostPosted: September 6th, 2007, 10:55
FW should be enough...
PostPosted: September 10th, 2007, 11:14
So in most cases if the config code is different but the model and firmware are the same it should work with Seagate Disks?
Users browsing this forum: Google [Bot] and 220 guests
