 Post subject: Seagate ST96812AS PCB Swap
PostPosted: September 10th, 2007, 14:41
Hi I have a Seagate ST96812AS with a burned PCB. My drive FW is 7.01 and I found a replacement drive to buy with FW 3.06. Also the PCB are different. Is there any way that it will work OK.
 Post subject: Re: Seagate ST96812AS PCB Swap
PostPosted: September 10th, 2007, 14:42
No, it won't work.
You need same F/W, at least
PostPosted: September 12th, 2007, 13:26
You'd better hope the heads haven't failed as well.
See here
http://www.retrodata.co.uk/notice_apple ... drives.php
PostPosted: September 15th, 2007, 12:51
These both pcbs are not even of the same family . Try repairing the burned pcb as u will have a hard time finding this pcb because its very old .
Users browsing this forum: Google [Bot] and 82 guests
