Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: WD5000AAKS SATA 500G what are these chips?
PostPosted: September 14th, 2007, 3:40
Hi Gurus
I have WD5000AAKS SATA 500G, it sounds like it is not enough power to start the motor, strugling to start.....it is not the motor problem or sticktion i have checked.
I suspect the motor controller SMOOTH L6284 but not 100% sure as i don't have the datasheet, anyone got one?
I have an identical drive with different firmware WD5000AAKS , swapped pcb from faulty drive to good drive, it sound exactly the same strugling to start motor.
Unfortunately WD5000AAKS has no flashrom, i think it is embedded in MCU, does anyone have any experience with this drive? Please look at the photo, what are these chips marked as U21 and U23? There's another one close to RAM but unmarked.
Thank for your help.
 Post subject: Re: WD5000AAKS SATA 500G what are these chips?
PostPosted: September 14th, 2007, 9:02
if the spindle runs freely, check the motor windings with an ohm meter and compare the values to the working one!
PostPosted: September 14th, 2007, 9:43
Hi Pepe, yes the windings ok, 2.2ohms, do you think its the motor controller L6284 problems? Q1,Q2 etc are ok, diodes ok too :(
PostPosted: September 14th, 2007, 12:04
Does the spindle rotate freely?
PostPosted: September 15th, 2007, 0:38
yes spindle is rotating smoothly, i suspect the pcb...this is another tough one to crack.
PostPosted: September 15th, 2007, 1:32
U told in your first post U swapped the PCB and got the same result...
PostPosted: September 15th, 2007, 1:35
hi Pepe, a little misundertanding here....i swapped good pcb to bad hdd ..then the hdd is fine but because different firmware the drive only recognized as alias. However i took bad pcb and put in good hdd, the drive strugling to power up. sorry for the misunderstanding.
PostPosted: September 15th, 2007, 2:09
Then swap ROM, or read it out and program into the good one.
PostPosted: September 15th, 2007, 3:14
pepe, ROM is i believed embedded into MCU, i cannot locate any ROM on pcb :(
PostPosted: September 15th, 2007, 4:54
Drive...
MDL: WD5000AAKS-xxxxxx ?
PCB: 2060-xxxxxx-xxx ?
Mikippp
PostPosted: September 15th, 2007, 9:30
This is the pcb, can't see any ROM
PostPosted: September 15th, 2007, 12:58
ROM place on this PCB is U12
If drive is recognized as alias with good PCB... U have problem with SMOOTH...
U must replace SMOOTH, or find the same drive with very similar date... (the same ROM version)
PS Can U read ROM in PSV (kernel) mode...?
Mikippp
PostPosted: September 15th, 2007, 21:45
Hi Mikippp
The drive model is WD5000AAKS-75TMA0, its off DELL
PCB: 2061-701477-800 AB
PostPosted: September 15th, 2007, 21:48
Mikippp, my pcb does not have the ROM chip, please see the photo i attached above, noticed the ROM chip isn't installed.
PostPosted: September 16th, 2007, 7:28
Possibly some one else desolder it before that HDD get to your place TerraNova ?
My Forum
PostPosted: September 16th, 2007, 8:58
no cry, the new sata WD no flashrom, i have check WDs 320G 500G and 750G SATA all no flashrom
PostPosted: November 9th, 2007, 15:57
Hello my friends,
I read this post, but I don't see the answer how to match donor PCB for this drive if it has no ROM as Terranova realised? What is "uniqe" which I must recover from burnt PCB to get access to my drive?
I have exactly the same as Terranova:
MDL: WD5000AAKS-00TMA0
DATE: 25 JAN 2007
DCM: HANCNV2AB
My also is also burnt :cry:
Best Regards
Damon
PostPosted: November 10th, 2007, 2:57
Yes. I have discover that this New Model AKS From WDC have No ROM. Rom was embedded in MCU. I suggest try to change SMOOTH Chip. If Not Change MCU but it hard to do.
thanks
Спасибо
СУТИОНО / АПИНГ
PostPosted: November 10th, 2007, 14:52
Yes. New WDC SATA drives AAJS AAKS BEVS... have No Rom.
(Processor is 88i6745 instead of older 88i6545)
88i6545 need external serial Flash.
88i6745 have Flash memory embeded.
If processor is not damaged - it is possible to read ROM in PSV mode (4-jumpers)
Mikippp
PostPosted: November 11th, 2007, 2:37
Swapping the MCU is not hard if you have a hot air station. I certainly wouldn't attempt it without one.
Jon
http://www.datasaversllc.com
