 Post subject: heads touch
PostPosted: September 16th, 2007, 18:23
If the heads touch each other are they toast?
 Post subject: Re: heads touch
PostPosted: September 16th, 2007, 18:53
Not always Cobra.
If you can separate them easily, then there is mostly no problem.
But if the heads stick together so you have to separate them with force, then they are unuseable thereafter.
Regards,
Dobre
Murphy was an optimist
PostPosted: September 16th, 2007, 20:23
I was working on a Toshiba 2 platter drive. I don't think they stuck together. But after reading some here on the forum it seemed that it would be bad if they did.
I got the drive back together, but it doesn't pull up. I don't think I got the platters aligned right. Either way it's toast I am afraid.
Thanks for the fast response tho.
PostPosted: September 16th, 2007, 22:05
I have had Toshiba heads touch without any problems.
However, with Fujitsu it seems like certain death. It's best to always take steps to keep them separated, just in case . . .
Jon
http://www.datasaversllc.com
PostPosted: September 17th, 2007, 3:38
How abaout for Maxtor ???
any experience ???
Спасибо
СУТИОНО / АПИНГ
Users browsing this forum: Majestic-12 [Bot] and 92 guests
