 Post subject: Question about Seagate PCB Problem
PostPosted: September 17th, 2007, 3:49
Hi All,
I have a Seagate ST3320620AS 80 GB SATA Hard disk with the following info on the drive label:
P/N: 9BJ14G-033
Firmware: 3.ADG
Date Code: 07406
Site code: WU
REV: A00
This is out of a Dell Computer and i have searched for an identical part for 3 weeks, found nothing with the same P/N and Firmware.
This hard disk does not spin up or get detected. The hard disk has 3 protective diods, this does not appear to be the problem.
Are they are common problems like the DIOD problem which i should check to troubleshoot this disk?
The purpose of this is to recover the data on the disk.
Thanks for any help you can suggeste.
 Post subject: Re: Question about Seagate PCB Problem
PostPosted: September 17th, 2007, 4:33
is this correct ? I thought it should be Seagate 320 GB SATA 16 MB cache ?? CMIIW....
ST3 = Seagate Tehnology 3rd generation
320 = capacity (320 GB)
6 = 16 MB (cache)
20A = firmware model (Galaxy)
S = SATA
How can it be 80 GB SATA ??? I don't get it ?
My Forum
PostPosted: September 17th, 2007, 7:14
Sorry - it is a 320GB.
I have so many HDDs to work on this week, i got it mixed up.
PostPosted: September 17th, 2007, 8:39
hi zed, i've got one, pm me where you locate
PostPosted: September 17th, 2007, 9:56
PM Sent but in the mean time, are there any common problems known with this model disk and any common troubleshooting methods? (e.g like the DIOD Check).
PostPosted: September 17th, 2007, 10:06
zed, enable your private message, i cannot PM you
PostPosted: September 18th, 2007, 1:12
Why PM ? :shock:
zed :
Check the protective diode. If it's burnt (no sign of damage physically), then it's rotor problem. Drilling method needed. I haven't tried it yet on this model...
In case protective diode is OK, that means head(s) problems. One or more heads might stuck (glued) to the platter. You may not need a donor. Open the HDA case, and spin the rotor manually and head(s) synchronously. Set it back to its original position and then, test it again... 8)
My Forum
PostPosted: September 20th, 2007, 22:30
ST= Seagate Tehnology Brand
3 = 3.5" Hard Drive. 9 = 2.5" HardDrive
620 = Specific Model
A = PATA
AS = SATA
I hope This help :)
6 = 16 MB (cache)
S = SATA
Спасибо
СУТИОНО / АПИНГ
Users browsing this forum: Google [Bot] and 82 guests
