 Post subject: Toshiba 2.5" SATA Disk - Clicking and beeping, any ideas?
PostPosted: September 8th, 2007, 10:31
Hi All,
I have a Toshia MK1032GSX 2.5" SATA Disk. When you apply power to the disk the disk clicks and makes a beeping sound. If you power it off, then power it on holding the disk upside down or at another position the symptoms may be less/more severe.
Before i go ahead and order another disk to swap the heads, does anybody think it may be something other than a head problem?
i.e will a head swap fix my problem in most cases like this?
Any suggestions would be most helpful.
 Post subject: Re: Toshiba 2.5" SATA Disk - Clicking and beeping, any ideas?
PostPosted: September 8th, 2007, 15:35
hi,
Might be problem with the bearing.
PostPosted: September 8th, 2007, 15:39
could be bearing. but head problem is also common on these
apart from the beeping sound, does the spindle sound OK?
i.e. no rattling or other untoward noise?
PostPosted: September 8th, 2007, 22:18
The drive sounds like it's spinning normally but it makes a clicking and beeping sound every now and again, sounds rather violent!
If it is a bearing problem, what's the solution? Platter swap into another working disk?
PostPosted: September 12th, 2007, 8:36
zed wrote:
Hi All,
Bearing problem....
My Forum
PostPosted: September 12th, 2007, 8:37
PostPosted: September 16th, 2007, 9:47
Hello zed, yes that's correct...platter swapping.
My Forum
PostPosted: September 17th, 2007, 2:37
Thanks, i tried that and it was pretty simple with this model disk. It worked well - the disk worked for a few hours then crashed again, it was enough time to clone it using copyr. Thanks!
PostPosted: September 17th, 2007, 3:43
Very nice to hear that ! :D :D :D
My Forum
PostPosted: September 17th, 2007, 9:57
For a change, it went smoothly and without any instability - the drive imaged fast and without errors or odd sounds. Thanks for your help again.
PostPosted: November 29th, 2007, 21:19
I have same problem wih my HD ... how would I swap paltter because I have no similar Hard Disk
PostPosted: December 1st, 2007, 7:44
U will need to get one, otherwise u may try to put the platters into a kitchen machine and see if it gives some data :)
Users browsing this forum: No registered users and 100 guests
