Forum rules
 Post subject: I will be the first
PostPosted: September 20th, 2007, 18:12
One nuance I have not been able to discover is whether the heads read data simultaneously or if the preamp is also a multiplexer allowing the controller to read one head at a time.
Thanks, Ben
 Post subject: Re: I will be the first
PostPosted: September 24th, 2007, 8:33
Heads never read data simultaneously. It is impossible in modern hard drives due to the simple fact that heads can change their position relative to other heads due to temperature/vibration/etc. So, hard drives read with one head at a time and preamp is also switching heads besides amplifying signals :)
Dmitry
Dmitry
PostPosted: September 26th, 2007, 4:49
found this forum working great withthe support of slavation company...
also find pc3000 firmwares and discussion..
SPAM removed by admin. Beware: Diskanalyzers (diskanalyzers.com) is SCAM/FRAUD web site! They also spam forums!
registered there and get activation from admin...
PostPosted: September 26th, 2007, 5:03
PostPosted: September 29th, 2007, 0:51
Thanks for your reply. That is what i suspected, but why then is the alignment of the platters and of the heads so critical. Couldn't the hard drive use the servo tracks on each individual platter in order to successfully read the data?
Ben
