 Post subject: IBM deskstar DTLA-305040 burnt motor controller
PostPosted: August 29th, 2007, 3:04
hi gurus!
i have IBM deskstar DTLA-305040 with burnt motor controller, i replaced it and still not powering up, maybe other components? please help me ....
The 90G2018 motor controller shown on photo has been replaced.
 Post subject: Re: IBM deskstar DTLA-305040 burnt motor controller
PostPosted: August 30th, 2007, 13:58
What did u replace it with Hot gun or with soldering iron if u used just hot gun then resold it with soldering iron sometimes pins dont usually touch the points .
PostPosted: August 30th, 2007, 21:09
soldering iron, yes rameez i have checked the connections are ok and properly connected.
PostPosted: September 1st, 2007, 15:38
if u can find another board of the same family DTLA transfer the orignal NVRAM to that pcb ur drive will work fine after that .
PostPosted: September 1st, 2007, 22:22
thanks rameez i will try it out.
PostPosted: September 5th, 2007, 3:41
Rameez i swap ROM it doesnt work, the faulty pcb has 25FV101T chip and S93C6 ROM, the replacement PCB i have has no 25FV101T chip.
I have tried measuring Q1, Q2, Q3, U9 all ok, could it be the Read Channel chip? D1 and D2 at the back of the pcb are also ok. :(
PostPosted: September 6th, 2007, 14:16
u will have to find the same pcb that has both ROM and NVRAM present like in your pcb if u have trouble finding the pcb give me info i will look in my stock .
PostPosted: October 1st, 2007, 23:12
Rameez, it doesnt work i tried swapping ROM and NVRAM, IBM deskstar as far as i know not easy to swap ROM and NVRAM unless same version. Anyone have any clues? Thank's
PostPosted: October 2nd, 2007, 12:53
On which pcb did u solder the orignal nvram of the drive , what did the drive do after u swap pcb and nvram ?
PostPosted: October 2nd, 2007, 13:57
in your photo i also see a mosfet/regulator with a hole ?
PostPosted: October 2nd, 2007, 21:35
Rameez, the drive clicks after i swapped NVRAM and ROM to donor identical pcb.
Amarbir the hole is the manufacturing hole, its is tested working. I still could not figure out why the drive will not power up, i have identical pcb board, i swapped the NVRAM and ROM and still would not work. ummmm headache.... :(
Heeeeeeeeeeellllllllllpppppppppp!
PostPosted: October 3rd, 2007, 4:00
Hi Terranova,
Did you check if the nvram is still readable ? (use eprom-programmer)
Because, if the nvram is defective or corrupt, the drive will not start either!
Best regards,
Dobre
Murphy was an optimist
PostPosted: October 3rd, 2007, 6:19
dobrevjetser , thanks...i swapped the nvram and rom to donor identical pcb and the drive starts but clicking...so i think it must be working....not sure...i dont have eprom programmer to check individual chips...
PostPosted: October 4th, 2007, 1:27
Most probably U are facing a burnt preamp....
PostPosted: October 4th, 2007, 3:55
hi Pepe, thanks i will give it a try changing hda.
PostPosted: October 6th, 2007, 23:02
Today before i do head exchange the drive starts up but the motor controller chip gets really hot, i mean untouchable.
PostPosted: October 8th, 2007, 3:48
try to use SA Switch.. Sometime it because of its motor controller IC too HOT..
Спасибо
СУТИОНО / АПИНГ
PostPosted: October 8th, 2007, 3:56
prodata tried that doesnt work thanks :(
PostPosted: October 9th, 2007, 0:48
Tried replacing 90G2018 today same results.
Is read channel exchangeable? I suspect the read channel chip is blown cause all major parts warm except the read channel chip dead cold. :roll:
PostPosted: October 9th, 2007, 14:42
just replace the MHA, put the prepared donor PCB on the drive afterwards, it should work...
Users browsing this forum: Google [Bot], melvin and 57 guests
