 Post subject: WD2500JB-00REA0 Translator Modules
PostPosted: October 4th, 2007, 1:16
Hi HDD Gurus,
I hope some smart guys here can help. The documentation I have says that the translator modules for WD XXXJB drives are in 20 and 25. When I look at a good drive of that model, it doesn't even have a module 20, and 25 is a log module. Can anyone tell me which modules are the critical translator modules needed for a smart hot swap(as Starling calls it) for this model of WD drive?
Thanks for your replies!
A
 Post subject: Re: WD2500JB-00REA0 Translator Modules
PostPosted: October 4th, 2007, 5:19
Sounds like a "Black II" type drive, marvel chip.
Modules 31 & 32
Copy to donor, regen translator and then hot swap.
PostPosted: October 4th, 2007, 8:32
Thanks Sean!
Cheers,
A
PostPosted: October 4th, 2007, 8:47
By the way, this HDD has an L-shaped board, which, according to SD documentation, should be a Black I. Maybe it's a mistake. An when I use Autoconfig, it puts it under Black I. Weird...
Well I got module 31, but couldn't get module 32(CRC Error). I'll try the hot swap anyway, but not sure about the prospects...
Thanks for the help though!
A
PostPosted: October 4th, 2007, 8:52
Are u using Salvation or PC3000 to do this?
PostPosted: October 4th, 2007, 10:28
I'm using Salvation Data.
A
Users browsing this forum: No registered users and 40 guests
