Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: IBM deskstar DTLA-305040 burnt motor controller
PostPosted: October 9th, 2007, 22:50
Hi Pepe, today i replaced MHA and exactly the same problem. This drive is really the Devil's drive :cry: but i will not give up
PostPosted: October 10th, 2007, 11:05
have U tried the patient MHA in the donor drive? just to check if it is OK or not...
PostPosted: October 10th, 2007, 11:38
yes Pepe after replaced the MHA over it had same problem, so i took the original ( we thought faulty) MHA and placed to good donor and the head works fine. Could it be the READ channel chip? All other chip warm except this one.
PostPosted: October 10th, 2007, 11:54
since U used the donor PCB I suppose with the donor heads in the patient, I don't think read channel could be the cause here.
What I think is that writing was turned on when the PCB or the preamp damaged, so there is no servo as well as data left on the platter...
I had such experience at least twice...
PostPosted: October 12th, 2007, 1:32
You know one thing i love doing data recovery is when successful i get a sense of "Multiple Orgasm" YES sometimes better than sex :D :D
Finally the drive is working and data copied.
All credit goes to all who posted in this forum, thank you all, especially PEPE who gave a great help in tourbleshooting and guidance.
Thank you guys.
Solutions:
Apparently the Head is not completely dead but for some reason failed, after following Pepe's adviced i remove faulty head and ROM and the drive works perfectly, yes the old PCB is faulty.
Users browsing this forum: Google [Bot] and 55 guests
