 Post subject: PC3000 Utility Status showing error? SA Head =
PostPosted: October 17th, 2007, 17:15
Dear PC3k Guru's
In PC-3000 (UDMA), when using Utility to copy data from good donor drive; am seeing SA Head="45510" which prevents loading modules etc. When set SA Head=2, can read modules OK.
Any suggestions?
scegs
 Post subject: Re: PC3000 Utility Status showing error? SA Head =
PostPosted: October 17th, 2007, 17:30
Hi Sceggy,
What drivemodel are you talking about ?
Dobre
Murphy was an optimist
PostPosted: October 17th, 2007, 17:33
Dobre
Thx 4 quick response. I've got another damn Maxtor 53073U6 ....
Bizarre!
scegs
PostPosted: October 17th, 2007, 17:36
Hi Sceggy,
Never got this one.
According to you report i would suppose UDMA has trouble reading its parameters.
I'll look if i can find such a type in my stock and see what UDMA is reporting.
I'll keep in touch.
Dobre
PostPosted: October 17th, 2007, 17:57
Dobre
PC-3000 does not recognise the drive type, though reads Model, Serial, Firmware, Capacity OK.
HDD Identification has been read
Read roadmap: Ok
Read roadmap extension: Ok
Read zone allocation table: Ok
Read Technological ID: Ok
Read Zone allocation table extension: Ok
SA head : 44510
Ext Model....
HDD structures have been read successfully
In UTILITY STATUS:
Selected family Proxima
Utility status
ROM_SA Check Sum 0000
Loaded ROM Check Sum A5EA
Model (version)
SA head 44510
[If change SA head to 2, can do SA surface verification ok, otherwise just Maxtor techno command error. Command: 43 Code: 181 C/H/S : x/x/x etc etc]
In addition, if create a Loader from this drive (with SA head = 2 3 4 5 6 or 7) Service Information -> Loader -> (creates without errors) ; and then attempt to use Loader in safe mode... HDD ID reading OK (well Maxtor DRACO default capacity 20018326 as to be expected), but when execute LDR file loading I get "Error loading firmware. Sector 1/257 (ABR)"...?
Am I missing something, or been working too many 16 hour days....???
scegs
PostPosted: October 17th, 2007, 18:18
Hi Scegs,
I've seen this situation with other maxtors too.
The problem is that ace has no support for these drives built in the utility.
They probably use other techno commands than the other series, so the settings cannot be identified in a correct way.
Working with the SA on this drive is risky business IMHO :)
Dobre
PostPosted: October 17th, 2007, 19:41
Are you sure it's Proxima?
PostPosted: October 18th, 2007, 2:40
Can't be 100% sure [PC-3000 not clearly recognising it upfront], matches on:
DSP, Lucent, 78L08A, 48LC1M16A1
Rotation of SH6770C semiconductor by 90 degrees.
PCB Marked Maxtor DRACO II 301283100
Guess that's the problem with OEM drives!
scegs
PostPosted: October 18th, 2007, 7:58
This hdd is not Proxima its Nebula . I think UDMA dont support this drive .
PostPosted: October 18th, 2007, 8:57
Rameez et al..
Nebula might make sense ... and thanks for the additional information.... any tricks on trying to extract SA firmware from the donor to fix a knocking target drive?
scegs
PostPosted: October 19th, 2007, 4:08
so old type you can try use ISA version!
good luck
wawalab
PostPosted: October 19th, 2007, 9:54
yes wawalab is right only ISA will help u with this version or u can use HDD repair 2.0
PostPosted: November 2nd, 2007, 6:47
Thanks for all your input. Managed to resolve this one....
Users browsing this forum: ccc and 258 guests
