 Post subject: Toshiba MK8026GAX bering problem?
PostPosted: November 4th, 2007, 12:23
Hi All,
I have problem with Toshiba MK8026GAX.Disk working a few minutes and stop.I heard this model has usually problem with bering, and i can heat the motor with a hot air gun. How long heat the motor? How high temperature set up on hot air? I wont copy data on second disk with copyr program and now I can because disk clicking and beeping and finally stop.
Any suggestions would be most helpful.
 Post subject: Re: Toshiba MK8026GAX bering problem?
PostPosted: November 4th, 2007, 13:51
I have not had good luck with heating or re-lubricating the bearing.
I gave had a lot of success with transferring platters and heads to a drive shell with a working motor.
Your drive is a little tricky because there are two platters and 3 or 4 heads.
Jon
http://www.datasaversllc.com
PostPosted: November 4th, 2007, 14:01
I don't have a donor :( and I'm not a specialist in data recovery :) this is first disk whitch I try recovery somthing.
PostPosted: November 4th, 2007, 22:08
Donors are easy to find. Yours is very common.
Don't try the platter swap if you value the data. Send it to a pro.
Jon
Users browsing this forum: No registered users and 264 guests
