 Post subject: Quantum fireball Plus AS 40G how to find identical head?
PostPosted: November 2nd, 2007, 3:18
Hi guys
How to find out matching Head in Quantum fireball Plus AS 40G ? The alphabetical code on HA must be same , where is the alphabetical code located? firmware must be the same? country must be the same too?
Thank's so much.
 Post subject: Re: Quantum fireball Plus AS 40G how to find identical head?
PostPosted: November 5th, 2007, 18:49
it is almost impossible to find a matching head for AS40, the heads' alignment is unique.
PostPosted: November 5th, 2007, 20:06
Hi Pepe
So how to resolve the issue of the head's alignment? There is no form of matching codes on the label that can be used?
PostPosted: November 6th, 2007, 2:06
I don't have deep experiences with AS and I never had anything to do with 4 head AS.
the most I did was AS30, but I could bring it alive for some minutes only.
the first character of the code is the most important and it must be matched, it is related to head type.
Recently I had however an LC30 drive which has 4 heads too, but it didn't worked out good...
regards,
PostPosted: November 6th, 2007, 5:52
thank's pepe
PostPosted: November 7th, 2007, 0:36
hi spildit preamp is dead so i dont think cleaning will make any difference.
PostPosted: November 7th, 2007, 14:38
Then it is easy!!!!
just replace the preamp, the old heads are probably OK, and more, perfectly aligned!!!
PostPosted: November 7th, 2007, 21:44
thats true Pepe, but unfortunately one of the head is busted and bent. :cry:
Users browsing this forum: Google [Bot] and 238 guests
