 Post subject: MAXTOR N40P PROBLEM
PostPosted: November 6th, 2007, 13:17
Hi to all.
HDD 6E020L051006 KMGA
ARDENT C9 - C1
PCB B8FEA
IN PC3K ISA
MAXTOR N40P FW NAR63G4Z
ERR ABRT
LBA 0 SIZE 0
IN STANDART MODE
LOADMAP LOANDING ERROR
NECESSARY TO RECOVERY THE DATA...
already I have loader 6E020L0.LDR
Normal league and no abnormal sound in hdd...
I load loader in the safe way?
which stages that I must follow?
Thanks advance!
Нет ничего невозможного
 Post subject: Re: MAXTOR N40P PROBLEM
PostPosted: November 7th, 2007, 9:03
UPDATE
ERRORS IN MODULES
45A0:0002 # 00 (45A00002.RPM)
0029.000B (00290139.BAD)
SOMEBODY KNOWS WHICH HERE the FUNCTION OF EACH MODULE?
necessary of the data
If I can rewrites them of one hdd good?
thanks advance
PostPosted: November 7th, 2007, 9:27
UPDATE
I rewrote module 45A00002.RPM, and I repaired dcms, ulist, plist, glist and comes back the problem with the same modules.
PostPosted: November 8th, 2007, 9:28
UPDATE
ERRORS IN SA
DATA, copy 1; UBA = $0008; Size = $04B0
Defects amount : 74
UBA: 164 - 189 Err: 04H UBA: 218 Err: 04H
UBA: 282 - 285 Err: 04H UBA: 287 - 312 Err: 04H
UBA: 314 - 315 Err: 04H UBA: 317 - 318 Err: 04H
UBA: 320 Err: 04H UBA: 323 - 324 Err: 04H
UBA: 326 Err: 04H UBA: 329 - 330 Err: 04H
UBA: 332 - 333 Err: 04H UBA: 338 - 339 Err: 04H
UBA: 342 Err: 04H UBA: 344 - 345 Err: 04H
OVL, copy 1; UBA = $04B8; Size = $1140
Defects amount : 0
Self Scan; UBA = $2D68; Size = $0CE4
Defects amount : 0
SWAP1; UBA = $3A4C; Size = $0B54
Defects amount : 2
UBA: 17284 - 17285 Err: 04H
SWAP2; UBA = $45A0; Size = $0190
Defects amount : 14
UBA: 18090 - 18094 Err: 04H UBA: 18101 Err: 04H
UBA: 18107 - 18108 Err: 04H UBA: 18111 Err: 04H
UBA: 18117 Err: 04H UBA: 18119 - 18120 Err: 04H
UBA: 18123 - 18124 Err: 04H
Defect log; UBA = $15F8; Size = $1770
Defects amount : 0
DATA, copy 2; UBA = $48C6; Size = $04B0
Defects amount : 28
UBA: 18786 - 18808 Err: 04H UBA: 18810 - 18812 Err: 04H
UBA: 19049 Err: 04H UBA: 19350 Err: 04H
OVL, copy 2; UBA = $4D76; Size = $1140
Defects amount : 0
ULIST, copy 1; UBA = $0000; Size = $0008
Defects amount : 0
ULIST, copy 2; UBA = $7E6F; Size = $0008
Defects amount : 0
what I have that to make to repair and to recovery the data?
Thanks advance!
PostPosted: November 8th, 2007, 10:24
Hi sempre,
please don't think am rude here :shock:
but if you don't know what is the function of 00290139 by this time
in the year of 2007 then maybe it is time to find another career path,
really.
00290139 is P-List (Factory defects list) and by the procedure
of "regenerate translator" you can re-create this "module" and
others
IF and ONLY IF "module" #33 is intact and
IF and ONLY IF
the media in the SA will allow this procedure to complete without
flaws.
PostPosted: November 9th, 2007, 7:48
coffebean
Thanks my friend!
:vo:
PostPosted: November 9th, 2007, 13:10
Hi to all.
expensive friend coffebean did not give certain continued the problem...
N40P
:shock:
PostPosted: November 9th, 2007, 15:12
If the drive makes knocking sounds there is suerly a head issue u can find a matching donor and transplant the platter to recover data .
And as u said that even after writing the modules that are bad they dont seem to repair so that means that the head is not writing properly .
PostPosted: November 9th, 2007, 15:35
Thanks rameez!
hdd not to be beating and nor emits abnormal sounds
:vo:
PostPosted: November 10th, 2007, 7:14
Hi to all!
update
1)when binding hd delays one 30 seconds for is ready (n40p)
2)hdd already arrived open and dirty platter with digital of the thumb of the user, of the opposing side of the data
:roll:
PostPosted: November 11th, 2007, 15:02
sempre wrote:
Hi to all!
update
:roll:
LOOK!
PostPosted: November 12th, 2007, 0:25
Sempre, on this HDD the heads read´s under the platter , so there´s no problem if u get a finger print on this side, but if u had some scratch on the SA, under the platter u could be get some problems , i find one of this Maxtor slimline with a head crash, the only way its lef´s the platter with handle and a clean enviroment, if this hdd was checking by another people, maybe they tried the platter swap, and believe or not, some people left the platter on the another side.
Best Regards
Alberto
