 Post subject: Seagate 7200.8 not getting on speed
PostPosted: November 15th, 2007, 5:48
Hi Friends,
I've got a 250 GB seagate 7200.8 that reports the following in the terminal:
Interface task reset
4096k x 16 buffer detected
TONKA - 1_Disk M-27 03-30-05 11:42
Buzz -
The heads do not move, so i guess it is not comming to the correct speed.
However, the spindle is rotating very smoothly. The heads and pcb have been changed without any progress.
Has anyone an idea what could be wrong here ?
Thanks in advance,
Dobre
Murphy was an optimist
 Post subject: Re: Seagate 7200.8 not getting on speed
PostPosted: November 15th, 2007, 7:11
in your place first i will try to let the hdd spinning for 1 or 2 hour and then check the terminal
PostPosted: November 15th, 2007, 17:21
Hello marc
Buzz its syntomph of FDB Problems :(
Best Regards
PostPosted: November 16th, 2007, 5:52
Hi Marc,
What do you mean by rotating very smoothly?
I must be spindle problems.
PostPosted: November 16th, 2007, 6:04
Hi David,
Well, according to what is see the drive is rotating at full speed; i cannot find any problem with the spindle.
Very strange.
Best regards,
Dobre
PostPosted: November 17th, 2007, 8:25
Dobre,
You sure it's not a stray screw stuck underneath the top magnet??!!
Duncan
PostPosted: November 19th, 2007, 6:40
Hi Duncan,
Thanks for the suggestion, but i've already passed that stage :)
However, i doublechecked and then noticed the disk had made a severe headcrash :(
All turned into data-dust (@ pcimage 8) ).
Best regards,
Dobre
PostPosted: November 19th, 2007, 15:18
Users browsing this forum: Majestic-12 [Bot] and 10 guests
