 Post subject: USB stick flashes 8 times, then nothing
PostPosted: November 14th, 2007, 9:27
I have a USB stick in for recovery.
When plugging into a USB port, it flashes 8 times and then - nothing.
All solder points have been checked, the main ones resoldered - to no avail.
Any ideas anyone??
Duncan
 Post subject: Re: USB stick flashes 8 times, then nothing
PostPosted: November 17th, 2007, 7:00
Spildit wrote:
Go to device manager and check if the drive is there.
If so most likely you will be able to recover data with restorer2000 pro.
There's not much point in trying recovery software if it's a hardware issue.
PostPosted: November 17th, 2007, 7:39
You will have to desolder the nand chip(s), and read it out externaly.
Then you of course need a Nand reader and software.
But it's possible to recover it.
Regards/ Bosse
http://www.rescue-it.se
PostPosted: November 17th, 2007, 10:12
Hi Boose
Can you please specify any NAND chip reader and procedure / software for the same? How will be output ?
Thanks in advance
Hddbug
PostPosted: November 23rd, 2007, 14:36
I made one for myself...
There are some programmers like Xeltek that can read these memories, but I didn't have much success withit till died.
