 Post subject: Hot Swap
PostPosted: November 21st, 2007, 3:49
hi fellows.
i am a newbise. tell me any body about hot swap prosedure of maxtor hard drive
thanks
 Post subject: Re: Hot Swap
PostPosted: November 21st, 2007, 19:39
First of all
Why would u need to do hot swap?
Some history would help.
PostPosted: November 23rd, 2007, 3:40
Hi pcimage!
extually i have a wd hard drive WD400BB - 75CLB0 and i have need data. when i give only give it up power hard drive did not spin at all. its motor ic is damage. i want to replace its pcb. please give me some information how i change the pcb. because when i change the pcb and give the power hard is cliking noise.
PostPosted: November 29th, 2007, 4:16
hi,guy
easy!
solder the born motor IC(please pay more attention to the parameter printed,should be special for WD brand) from the bad PCB and get a identical good one insteaded.if you not sure you can do it on you own,ask somebody who can to help you,just pay a little meony after that . :P
PostPosted: December 12th, 2007, 14:46
After changing the pcb u also need to solder orignal ROM on the new pcb .
Users browsing this forum: No registered users and 60 guests
