 Post subject: maxtor safe mode detected
PostPosted: November 27th, 2007, 4:28
hi! i've have problem.when i check using PC3k, it not detect my hard disk. It appeared "safe mode detected". i try to solve - load in safe mode condition and try to run SA structure test. it found a few error. then i change back the jumper to master and try to run utility test again. but i won't detect.
so my question is : is there any step i need to do after i load?
i have changed PCB because i thought its PCb problem..but still not working
Maxtor DiamondMax Plus 8
6E040L0510605
fw: NAR61590
SN: E1D501FE
KMGA
i'm still new in this field..plsss...need some clue or advice...
thanks
 Post subject: Re: maxtor safe mode detected
PostPosted: November 27th, 2007, 4:44
Hi Ariann,
You first have to correct the SA modules in safe mode before you can get the drive correctly working again.
Read the manual on how to restore SA modules and be very carefull.
Be sure to backup all modules before you change any!
Best regards,
Dobre
Murphy was an optimist
Users browsing this forum: Google [Bot] and 144 guests
