 Post subject: HELP! Unrecognized Seagate ST500630A 500GB IDE
PostPosted: December 1st, 2007, 14:34
I have a Seagate ST500630A 500GB IDE drive that is making the noise in the attached sound file. (it won't upload! - but it's a repetitive access noise - not
unlike a click, but not really a click) And the drive will not identify or initialize in Windows.
The firmware is: 3.AAE Date Code: 07497 Site Code: TK
Is the problem in the controller board? If so, does the firmware code need to be matched? Matched exactly?
A local supplier has many of these in stock, so I'd like to know what to ask them for.
Thanks!
 Post subject: Re: HELP! Unrecognized Seagate ST500630A 500GB IDE
PostPosted: December 1st, 2007, 16:47
Okay, this might help: I replaced the controller board with one that matches the P/N and F/W exactly, and the drive makes the same repetitive-access-fail sound, with no initialization as all- it just stays "Busy".
This forum does not accept ,mp3 files, so I put the sound file at this url:
http://www.quikpro.ca/seagate.mp3
Next step anyone?
TIA!
PostPosted: December 2nd, 2007, 11:49
Heads
PostPosted: March 19th, 2008, 6:54
Could you solve your problem?
I have a Seagate HDD that is making the same noise after I had installed it in an IcyBox (external USB housing).
René
Users browsing this forum: Google [Bot] and 109 guests
