 Post subject: Western Digital Drives Help
PostPosted: November 17th, 2007, 20:21
WD4000KD-00NAB0 SATA Drive
Begins to detect then as I am cloning drive in either MTL or Speedclone it slows down and comes to a stand still.
WD2000BB-00DWA0 IDE Drive DSCHCVJAA same behavior
I have PC3000PCI and if it is firmware please send to my PM or your thoughts if it maybe head stack replacement.
Thank you..
 Post subject: Re: Western Digital Drives Help
PostPosted: November 25th, 2007, 12:12
Check Surface in universal utilities in pc3k .
PostPosted: November 27th, 2007, 19:51
WD4000KD-00NAB0
SA structure test
SA MODULES LIST
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
Zone allocation table
Number of zones......................... : 21
# : Initial cylinder : Final cylinder : SPT
0 : -32 : 31 : 888
1 : 32 : 9 023 : 1 166
2 : 9 024 : 17 343 : 1 152
3 : 17 344 : 25 439 : 1 134
4 : 25 440 : 29 183 : 1 123
5 : 29 184 : 37 279 : 1 110
6 : 37 280 : 39 455 : 1 104
7 : 39 456 : 47 167 : 1 080
8 : 47 168 : 52 191 : 1 036
9 : 52 192 : 58 335 : 1 008
10 : 58 336 : 64 223 : 972
11 : 64 224 : 68 479 : 936
12 : 68 480 : 70 591 : 918
13 : 70 592 : 73 759 : 891
14 : 73 760 : 79 167 : 864
15 : 79 168 : 82 271 : 820
16 : 82 272 : 86 207 : 792
17 : 86 208 : 90 911 : 756
18 : 90 912 : 94 335 : 720
19 : 94 336 : 97 759 : 691
20 : 97 760 : 98 622 : 678
CONFIGURATION SECTOR (42)
Not found in modules directory
Log DCM (C5)
Log Version Info (4E)
P-List (43)
G-List (44)
PostPosted: November 28th, 2007, 4:42
As Rameez says, surface test, not SA structure test. :-)
PostPosted: November 28th, 2007, 22:44
SA surface verification
Initial cylinder........................ : -1
Final cylinder.......................... : -20
Head.................................... : 0,1
Cyl -1 Head 0........................... : Errors : 0
Cyl -1 Head 1........................... : Errors : 0
Cyl -2 Head 0........................... : Errors : 0
Cyl -2 Head 1........................... : Errors : 0
Cyl -3 Head 0........................... : Errors : 0
Cyl -3 Head 1........................... : Errors : 0
Cyl -4 Head 0........................... : Errors : 0
Cyl -4 Head 1........................... : Errors : 0
Cyl -5 Head 0........................... : Errors : 0
Cyl -5 Head 1........................... : Errors : 888
Sectors :Error
0 -- 887................................ AMN
Cyl -6 Head 0........................... : Errors : 0
Cyl -6 Head 1........................... : Errors : 888
Sectors :Error
Cyl -7 Head 0........................... : Errors : 0
Cyl -7 Head 1........................... : Errors : 888
Sectors :Error
0 -- 30................................. AMN
31...................................... UNC
32 -- 34................................ AMN
35...................................... UNC
36 -- 182............................... AMN
183..................................... UNC
184 -- 293.............................. AMN
294..................................... UNC
295 -- 400.............................. AMN
401..................................... UNC
402 -- 441.............................. AMN
442..................................... UNC
443 -- 511.............................. AMN
512..................................... UNC
513 -- 515.............................. AMN
516..................................... UNC
517 -- 887.............................. AMN
Cyl -8 Head 0........................... : Errors : 0
Cyl -8 Head 1........................... : Errors : 888
Sectors :Error
36 -- 178............................... AMN
179..................................... UNC
180 -- 215.............................. AMN
216..................................... UNC
217 -- 256.............................. AMN
257..................................... UNC
258 -- 326.............................. AMN
327..................................... UNC
328 -- 474.............................. AMN
475..................................... UNC
476 -- 515.............................. AMN
Cyl -9 Head 0........................... : Errors : 0
Cyl -9 Head 1........................... : Errors : 888
Sectors :Error
Cyl -10 Head 0.......................... : Errors : 1
Sectors :Error
1....................................... AMN
Cyl -10 Head 1.......................... : Errors : 881
Sectors :Error
0 -- 1.................................. AMN
9 -- 887................................ AMN
Cyl -11 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -11 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -12 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -12 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -13 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -13 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -14 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -14 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -15 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -15 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -16 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -16 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -17 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -17 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -18 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -18 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -19 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -19 Head 1.......................... : Errors : 888
Sectors :Error
Cyl -20 Head 0.......................... : Errors : 888
Sectors :Error
Cyl -20 Head 1.......................... : Errors : 888
Sectors :Error
SA surface verification completed
THANK YOU FOR THE RESPONSES
PostPosted: December 1st, 2007, 22:02
Continue to get WD TECHNO READ ERROR C/H/S
Device Error Detected 51/01 (AMN)
PostPosted: December 3rd, 2007, 14:19
Most likely one of the non-system heads is weak. SA should be fine.
WD4000KD-00NAB0 is not supported by neither version of PC3000 yet.
Try head test in WD utility.
If you have Data Extractor you should try to create a headmap, see which head is bad and image by those that are good.
PostPosted: December 4th, 2007, 0:02
Here is the head map report
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 98591
Head Count.............................. : 8
SPT..................................... : 888
RAM:
Zone allocation table................... : Ok
ROM version............................. : 01.24.
SA FW version........................... : 01.24A
Link table version...................... : 06.EA.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : Default
Service area:
Modules table loading................... : SA Directory checksum error
Configuration loading................... : Module 42 not found in modules directory
Translation overlay checking (Copy 0)... : Not found in modules directory
Translation overlay checking (Copy 1)... : Not found in modules directory
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,2,3,4,5,6,7
Head 0................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
Thank you for your help.
PostPosted: December 4th, 2007, 10:40
- Either you have wrong head map(I don't remember now how many heads this model should have)
- Or someone tried to manually edit DIR.
- Or SA was erased completely.
PostPosted: December 4th, 2007, 10:53
Any suggestions? I have an I dentical drive and get the same results from the good working drive.
PostPosted: December 4th, 2007, 14:07
Hello post us here the complete report of the SA Structure u can try too MHDD to diagnostic, with the scan command, checking with Register Error show´s while´s reading sectors
AMNF, IDNF or UNC
Best Regards
PostPosted: December 5th, 2007, 16:09
dRIVE WAS HIT BY POWER SURGE SO POSSIBLY THE HEADS ARE BAD AND SHOULD BE REPLACED?
