 Post subject: Advice needed: Recovered files corrupted?
PostPosted: December 5th, 2007, 9:03
Hi Guys,
I successfully imaged a 2.5" Seagate to a .img file using getdataback 3.03 (FAT32)
Shortly after that, the drive squealed on me, to be honest sounds like the platter got scratched,
I have send the HD off for professional diagnosis.
anyhoo, the .img I have of the drive, I can mount it in getdataback 3.03 and scan for files.
It does find loads of files & directories, but when I try and open some of the files they are corrupted or incomplete .jpg's for example.
This would tell me that the files & drive is fragmented ????
Can anyone recommend any other goods software that might recover files from this .img of the HD?
winhex ???
Thanks in advance.
 Post subject: Re: Advice needed: Recovered files corrupted?
PostPosted: December 5th, 2007, 16:31
It is pretty hard to tell u what the exact problem is from the distance. I would surely inspect the file system structures directly and see what method to use to restore the data. The programs are good as far as U know what they can do and what they cannot. Sometimes it is needed to correct some structures manually before use any program. So U may try some progs, winhex is good as well, if U are familiar with file systems, but it is possible that U will need the services of a pro with that image file too.
regards,
Users browsing this forum: Google [Bot] and 173 guests
