 Post subject: WD2500JB-00REA0 only reconized in device management
PostPosted: December 3rd, 2007, 10:34
I have a WD2500JB-00REA0 hdd which was inside an external box : Memup Kwest.
It didn't reconized anymore in disk management, only in device management.
I plugged it on IDE and i have the same pb.
It is reconized in bios but all diagnostic tool i tried can't read any sectors ! All appairs to be bad (HDtune, HDD scan,DFT Hitachi, MHDD, HDAT, DLG DIag). There is no failure sounds.
I found exactly the same drive and try to swap PCB : it didn't work, drive isn't reconized in bios.
My PCB:
on paper: 2060-701292-C00
on PCB: 2060-701292-002
PCB with worked HDD:
on PCB: 2060-701292-001
I swap U12 firmware from my PCB to new PCB and plug this new PCB on my HDD : It works :) ...but ;) ......:
I have the same pb: HDD is only listed in bios and device manager , not in disk manager, so i can't read partition from it :(
Now i'm sure the pb isn't on my PCB, except the firmware, maybe it can be corrupted ?
Can you help me, i would like recover my data : a lot of pictures from many years :(
Can i test, read, update the firmware ?
What pb could it be ?
Thank you very much
See you later
 Post subject: Re: WD2500JB-00REA0 only reconized in device management
PostPosted: December 3rd, 2007, 11:03
Hi Nonob,
I think it is an SA problem.
That can only be solved with expensive tools and a lot of knowledge.
I think you best bring this disk to a professional data recovery company.
Best regards,
dobre
Murphy was an optimist
PostPosted: December 3rd, 2007, 11:44
What is an SA pb ?
thanks
PostPosted: December 3rd, 2007, 11:58
you have a problem with the service area of your hard drive ( the boot code) so it doesn't know where any of the sectors are. Do a search on this site and there are a lot of explanations for it.
I think ST is a sub company of Lucas
PostPosted: December 3rd, 2007, 12:07
Ok, so it is a pb on the disk . and do you know if i can try to restore my data ? With or without my second disk ?
Also, i found these software :
http://www.nazyura.newmail.ru/000006.htm
Could it help me ?
thanks
PostPosted: December 3rd, 2007, 13:49
What kind of errors do you get in MHDD and HDDScan when trying to scan the user area(for example: ABRT, IDNF, UNC...)?
PostPosted: December 4th, 2007, 4:35
Hi :)
I don't found how to scan "abrt" "idnf" or "unc" but when i do a scan from LBA0 to max ,
with MHDD, i have that :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ..Etc....
I don't know if it is important But i can change max lba.
With HDDscan, under windows :
I have BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB
BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB..etc...
But i saw something maybe important, i compared scan (verify or read) of My system HDD and scan of my "bad" HDD :
The difference is that the number "current LBA" change with my good HDD (increase) but NOT with my bad HDD,
but the bitrate KBytes/s is changing with the 2 HDD.
Maybe a tracking pb ?
Thank you
PostPosted: December 6th, 2007, 6:41
up
PostPosted: December 6th, 2007, 13:28
! - is ABRT error and it could mean either firmware or head problem. But it's definitely not a PCB issue and it's not something you can fix on your own, sorry. You need to have someone with PC3000 or Salvation data to check the firmware.
PostPosted: December 6th, 2007, 14:55
Thanks for your answer. If somebody can help me ..... :cry:
See you soon
Users browsing this forum: No registered users and 202 guests
