 Post subject: Help with Maxtor N40P Series
PostPosted: December 10th, 2007, 12:31
I have a couple of Maxtor 6E040L0 drives that are giving me fits. Both have the same symptom - they click and won't come ready.
I inspected one of them and saw no damage on the platter. I swapped heads by transplanting the platter to another good drive with the same codes. No change in symptoms.
While using safe mode, I can read drives' config info (1st screen after initialization). it reports correct capacity but only the generic model # and no S/N. The PC3000 utility reports "HDD structures have been read successfully" but then the drive times out with DRD, DSC, ERR, & ABT lights. I can't read firmware modules.
Hotswap doesn't seem to help. I've tried clearing G-Lists and SMART logs. No change.
Any other options / techniques that might help?
http://www.datasaversllc.com
 Post subject: Re: Help with Maxtor N40P Series
PostPosted: December 10th, 2007, 14:09
Hello jono
can u post us the SA structure here?
Best Regards
Sinceraly
Alberto
PostPosted: December 10th, 2007, 18:55
maybe the platter needs some alignment...
PostPosted: December 10th, 2007, 20:31
beto wrote:
Hello jono
Best Regards
Sinceraly
Alberto
Sorry . . . I cannot read the SA structure.
PostPosted: December 10th, 2007, 20:32
Interesting.
How do you align the platter?
Jon
PostPosted: December 11th, 2007, 5:09
This is interesting....
PostPosted: December 11th, 2007, 6:14
I think pepe means the alignment of the center of the platter.
In a singleplatter drive there is not much else you can do, isn't it? :wink:
dobre
Murphy was an optimist
PostPosted: December 11th, 2007, 7:45
Maybe thes olution is a platterswap. Did you check the filter to see if it is dirty? I have had many of these with platter damage it is not always easy to check.
PostPosted: December 11th, 2007, 9:26
He has already done that, check the first post!
Yes, I meant centering.
PostPosted: December 11th, 2007, 13:40
OK, here are the results:
1st Maxtor: Bad motor bearing made it impossible to read data. Swapped platter into another unit. Recovered 99.9%
2nd Maxtor: Head crash on S/A area. No recovery.
3rd Maxtor: Some moron had taken out the platter and not only got fingerprints and scratches on it, but installed the platter upside down! Once I figured that out, I was able to clean surface and begin recovery. But there are a lot of bad sectors to deal with.
Pepe is right. You can rotate the platter's position relative to the hub and get different results sometimes . . . even with one platter and one hub!
Jono
Users browsing this forum: No registered users and 47 guests
