 Post subject: Memorex Mini TravelDrive 6.50 2Gb
PostPosted: December 20th, 2007, 7:57
Hi to all!
Strange problem, recognizes using publisher hexa does not show no signal to me of data (nothing) as if had made one wipe.
Pparently access all the LBA without no data!
It has a total of lba 3932990, I used disk to explorer and gdbfat and gdbntfs.
For mhdd it recognizes more does not make scan (F4).
Somebody has a suggestion?
:vo:
Нет ничего невозможного
 Post subject: Re: Memorex Mini TravelDrive 6.50 2Gb
PostPosted: December 20th, 2007, 14:09
Try OnTrack's easy recovery and Raw recovery option, or deep scan with Recover My Files, or file recovery in WinHex.
Bosse
http://www.rescue-it.se
PostPosted: December 20th, 2007, 14:46
You tried to read with Winhex?
To see if there is actually any data on the drive?
PostPosted: December 21st, 2007, 7:29
Thanks all helps!
Also with winhex and in hexa 0000 and way text nondata!
I only read drive in the physical way, in the way of logical reading does not open...
I know that thus it does not have no signal of data, but distrust that it can have problems with firmware or another one any, therefore if I try to format for windows not accepted formatting!
I find stranger
PostPosted: December 26th, 2007, 13:43
Some aid?
:shock:
