 Post subject: WD400bb - 60DGA0 Problem ?
PostPosted: January 15th, 2008, 12:41
Hi Hdd Guru's
may someone can help me solve this problem. the drive doesn't spin up because
of the PCB. But when i swap the pcb it's looks good and trying to measure it's components
i found no problem.
may any one can help me ?
thanks anyway
sorry for my poor english
 Post subject: Re: WD400bb - 60DGA0 Problem ?
PostPosted: January 15th, 2008, 16:49
You need to swap the ROM also, when u change PCB.
PostPosted: January 15th, 2008, 23:07
on this model of wd40 only ? is that right ?
PostPosted: January 16th, 2008, 14:37
I am not sure how you tested the PCB. If you put it on another drive and the other unit did not spin up, then you may have a blown motor IC or corrupted ROM.
If you put a good board on your bad drive and it didn't spin up, then check the motor for an open or short.
Jon
http://www.datasaversllc.com
PostPosted: January 16th, 2008, 23:42
thanks for replies. but now i'm sure that the motor IC is corrupted.
the question now is should i swap the ROM from the old PCB ?
PostPosted: January 17th, 2008, 0:15
Yes, if you use a different PCB.
No, if you repair the one you have by replacing the motor IC.
Jon
PostPosted: January 17th, 2008, 0:34
thank u jon for ur advice. but i used to replace wd40 PCB without changing
ROM IC. EX : model : wd400eb - 11cpf0 ?
PostPosted: January 17th, 2008, 22:13
If you have an exact match PCB you do not have to change the ROM.
It is very difficult to find an exact match.
It is ease to find a close match and change ROM
PostPosted: January 18th, 2008, 18:56
thank u friends
Users browsing this forum: Google [Bot] and 55 guests
