 Post subject: xtal change fixed it!
PostPosted: January 18th, 2008, 15:04
A one gig cheapo usb pen drive appeared to be dead.
I tried resoldering everything but was still dead.
Out of curiosity I decided to change the 12 mhz crystal and voila drive came to life.
I suppose I should have put a scope on it beforehand. Next time I will.
 Post subject: Re: xtal change fixed it!
PostPosted: January 18th, 2008, 17:44
Glad you got it fixed. Actually, the crystal is probably by far the most shock-sensitive part on these. Some use ceramic resonators, which are much more durable.
PostPosted: May 14th, 2008, 17:24
Dick ,
Greeting From Amarbir ,Hi ,Yup Next Time Remember That the Crystal is the heart of this person ,If it Pumps Blood then Only the MCU Works ,Bad Soldering and Dry soldering Is Also a Major Issue
