 Post subject: Hitachi Travelstar SA Relocation on PC3K?
PostPosted: January 23rd, 2008, 16:32
I have a Hitachi HTS721. Drive doesn't read the passport but by manually selecting the model I can get to the utility. Running the SA check it shows that copy 0 of PSHT (P-list) is bad. I checked and there is a bad sector on it, although copy 1 works fine. I tried writing the modules onto an identical drive and doing hot swap but it didnt work.
Is there any way to relocate that module to another place (sector)?
 Post subject: Re: Hitachi Travelstar SA Relocation on PC3K?
PostPosted: January 23rd, 2008, 17:41
Ask ACE this question,
See if they know - probably one of few options for repair of fw for newer Hitachi.
They know, see if they will tell you - assuming you legal user, that is.
PostPosted: January 24th, 2008, 1:38
WEll, I hope this article will give you some help.
http://support.salvationdata.com/downlo ... hi_HDD.pdf
so far, SalvationDATA can support 7210, below models.
7210 HTS721060G9AT00 60
  HTS721080G9AT00 80
  HTS721010G9AT00 100
  HTS721010G9SA00 100
  HTS721080G9SA00 80
  HTS721060G9SA00 60
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: January 27th, 2008, 7:07
I have a Hitachi HTS541 with the same problem, damaged PSHT in copy 0 but copy 1 is OK. Can this be done within PC3K? I have both PCI and UDMA, surely one must have this feature?
PostPosted: January 27th, 2008, 12:04
You should be able to read the good copy and write over the bad (unless the media is bad at that location) using the PC3000.
IBM / Hitachi has 3 copies of the FW. One time I had a drive with all 0 copies testing bad; I replaced them with 1 copies and recovered 100%.
Jon
http://www.datasaversllc.com
PostPosted: January 29th, 2008, 6:10
If the media is bad where PSHT is stored, how can I repair this disk?
PostPosted: January 29th, 2008, 10:50
Is your chief goal data recovery or repair?
If data recovery, I think (but may be wrong - I haven't checked lately) that the Hitachi utility may allow you to choose to start from one of the other SA copies. I'd look for that. I don't know of a way to fix the underlying area on the HDU.
Jon
PostPosted: January 30th, 2008, 9:59
I only need the data. I can not seem to find this function. Anyone else know how to start the disk from an alternate copy? Copy 1 and Factory copy are both fine. I now have 2 exact disks with the same problem!
PostPosted: February 1st, 2008, 5:03
I have read within the UDMA PC3K manual that the hitachis have seperate copies of the modules but manipulation of these copies is not implemented in the current utility.
Maybe this is something I will need to look into Salvation Data for... :-)
Users browsing this forum: Google [Bot] and 213 guests
