 Post subject: HDD 2BO20H1
PostPosted: January 25th, 2008, 9:28
Hi to all!
Hdd already arrived pra me damaged with previous attempts to remove platter, will not use correct tool damaging the screw.
I have that to remove platter as I make to create a traction in the screw to loosen it?
Look photo!
Нет ничего невозможного
 Post subject: Re: HDD 2BO20H1
PostPosted: January 25th, 2008, 12:02
You can get screw extractors at a a hardware store. They look like tapered screws with reverse threads. You may have to drill a hole into the screw. Also, there is new product on the market called ScrewGrab thay may help. (http://main.screwgrab.com)
PostPosted: January 28th, 2008, 7:13
Thanks for help!
:good:
PostPosted: January 29th, 2008, 16:33
decided problem!
:good:
:vo:
