 Post subject: Self scan on MAXTOR
PostPosted: February 1st, 2008, 2:40
Need a little help using pc3 pci.
Problem with self scan calypso series.Start selfscan,clear modul33,reset logs,restart utility then start utill in self scan mode ,restart drive in most cases nothing hapens drive spis down afer 30sec,module 1f gets corupted.
And when i press immediately in self scan menu,after 10 mins nothing happens any sugestions?
 Post subject: Re: Self scan on MAXTOR
PostPosted: February 1st, 2008, 22:28
I suggest reading PC3000 bucklet, if you have it.
www.datarecoveryne.com
PostPosted: February 4th, 2008, 4:15
Yeas i have read the manual. :roll:
Rom sa and loaded rom matches,the drive starts normaly without safe mode,drive not using alternate SA.
Have 10 drives on every drive same,clear logs, start self scan,after restart,led blinks around 30 sec after that drive stops spining,led continues to flash.After that nothing. :cry:
Need a little help!
Thanks in advance
Alex
Users browsing this forum: Majestic-12 [Bot] and 117 guests
