 Post subject: replacing PCB for maxtor diamondmaxplus 9
PostPosted: February 10th, 2008, 12:39
hi all,
I have a Maxtor DiamondmaxPlus 9 80GB hd. An IC(W503) on the PCB was burnt with white fume and a little "light", seems due to bad power supply.
I want to get back my data.
I found some similar cases on the board, like this one,
http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/maxtor-160gb-harddisk-burnt-t7740.html?hilit=diamondmax
it's the same hd as mine, and the same IC got burnt.
Here are pics of my hard disk:
http://140.123.175.223/LOK/hd/1.jpg (front sticker)
http://140.123.175.223/LOK/hd/2.jpg (back)
So, I will try to find an PCB and replace it, though i know it dones't necessaily work since there might be something wrong in other parts. (seems its the easiest and an inexpensive way i can choose)
what i wanna ask is ,
How to choose a compatible PCB for my hd?
(if i get it from old hard disks, what code, KMBA, SN, TLA, and the code on the white label at the back are OK? )
(if i look for a PCB, what spec is OK?)
thank you for every help~
 Post subject: Re: replacing PCB for maxtor diamondmaxplus 9
PostPosted: February 12th, 2008, 14:58
Any pcb with cpu Agere Ardent C8-C1 would work on this drive .
PostPosted: February 13th, 2008, 7:57
Thx, i 've done it.
I replaced the PCB of my hd with one of code YAR41BW0, N,M,C,A, (6Y080P0) .
My hd is YAR41KW0, K,M,B,A, 6Y080L0. It works out and i am able to access my data.
Good luck to all burnt Hard disk owener~
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 202 guests
