 Post subject: Seagate Barracuda 300gb board fault
PostPosted: February 19th, 2008, 15:21
One of these 300gb Barracuda drives came in today.
On first inspection it appeard to be dead.
Further investigation showed it was short circuit on the 12vdc rail.
In fact it was an easy fix as the as the diode type component between the 12v molex type connector and ground had short circuited.
When replaced the drive was working and the data was able to be recovered.
All is good!
The bad side of this story was the drive had previously been sent to an OnTrack lab.
OnTrack had quoted £1000 ($2000) to recover the data. :evil:
The customer had declined the offer and came to us. :good:
 Post subject: Re: Seagate Barracuda 300gb board fault
PostPosted: February 19th, 2008, 17:06
Nice work, it's always good to scam the scamers 8)
Hopefully OnTrack learn something from it.....
And I'll bet your client is very happy aswell...
Bosse
http://www.rescue-it.se
PostPosted: February 25th, 2008, 13:42
Frankly, I do not think Ontrak is going to learn anything from this... I just do not see how, and I doubt that they really have to :)
Also, I do not think Ontrak has anything to do with scam.
Not to offend anyone, just my two cents.
Dmitry
PostPosted: February 26th, 2008, 23:42
All is good!
I have a sort of similar problem with the same type drive, except when I plug in the power connector it shuts down the computer. As the computer begins to restart, it shuts down again. I will do this indefinitely as long as the power connector is connected.
I also notice that one of the black, two prong diode, capacitor, or resistor(I assume its one of theses) becomes very, very hot.
Any suggestions on checking this out, and fixing it?
Any help will be appreciated.
PostPosted: February 27th, 2008, 0:33
Sure. Remove it.
PostPosted: February 27th, 2008, 12:45
£1000 :evil:
PostPosted: February 27th, 2008, 12:55
Nice Work ,
We Are Able to Make Some Money Too .Once this Protection Semiconductor is removed ,the hdd works fine but if in case the issue of spike comes again then the pcb gets totally busted ,better to replace by something similiar
PS : Wawalab You Do Not Reply to PM,I Had left a Request ,Is This The Frindship We share Here :evil:
PostPosted: February 28th, 2008, 23:49
How could I go about getting the right part for it?
Users browsing this forum: sixsweets and 278 guests
