 Post subject: repairing accidental format
PostPosted: February 21st, 2008, 21:00
I have a quick question, probably an easy one. I accidentally quick-formatted a hard drive. I used a recovery program to analyze the disk and list all of the files, which can be undeleted. But all of the files names are changed, and the directory folders/subfolders are not available. Is there a way to recover the boot information so that things can be put back the way they originally were (ie. original files names, folders, etc.)?
Thanks for your help!
- Scott
 Post subject: Re: repairing accidental format
PostPosted: February 21st, 2008, 23:39
It depends on the software you're using. Some are better than others, and some are better in certain situations.
Is your drive formatted FAT32?
PostPosted: February 22nd, 2008, 5:44
If your drive formatted FAT32, You can use tiramizu desktop bundle, hard drive mechanic for DOS
PostPosted: February 22nd, 2008, 7:33
I would suggest "GetDataBack" by runtime software
PostPosted: February 22nd, 2008, 14:17
Sir ,
You Need To Tell Us what Version was the initial format and what was the current format fat32 or ntfs or something else
PostPosted: February 23rd, 2008, 3:53
yes ,GetDataBack is my favorite.but you should note what kind of format do you want to deal with?that means "for NT"?or for "fat"?
PostPosted: February 23rd, 2008, 5:43
You have not mentioned if after the 'accidental format' a new operating system was installed? Is that why you can't see the folder tree and original file names?
The cheapest software out there to get the data back is Zeroassumption Recovery.
http://www.snapfiles.com/get/zeroassumption.html
Try out the evaluation version and see how you get on.
PostPosted: February 23rd, 2008, 6:14
Just to add there is a special weekend price on the authors site.
http://www.z-a-recovery.com/register.htm
single user license $29.95(US) ..........normally it costs $49.95(US)
It seems like a bargain to me!!!
PostPosted: May 2nd, 2008, 21:25
Even better is PCinspector file recovery, it's free and should be able to get it back. Version 3.0 is better than the newer one.
I think ST is a sub company of Lucas
