 Post subject: Western Digital WD2000JD-00GBB0
PostPosted: February 23rd, 2008, 7:09
I have one of these drives and it seems to be completely dead.
No power to it what so ever..
Could anyone advise as I have a lot of data I'd like to recover
 Post subject: Re: Western Digital WD2000JD-00GBB0
PostPosted: February 23rd, 2008, 9:53
Change the PCB.
But must swap ROM also.
PostPosted: February 23rd, 2008, 11:20
I have a working PCB for this drive.
You might have to switch ROM chip.
www.datarecoveryne.com
PostPosted: February 23rd, 2008, 19:36
moto chip burned?
PostPosted: March 2nd, 2008, 7:06
Here are some images of the PCB
Chip Side
Top of PCB
PostPosted: March 2nd, 2008, 7:21
Hi how much for the PCB?
PostPosted: March 3rd, 2008, 12:45
as far as i can see, the main processor unit is burnt, this is usually caused by overvoltage on the 5V power line. If this is the case, there is a high probability that the preamplifier circuit inside the HDA is also toasted, and if so, pcb replacement will not solve the problem and it might be dangerous to the good pcb also.
PostPosted: March 3rd, 2008, 16:21
Well I have got a new HD now, on the same line and it has worked perfectly for a few months now.. so unless there was a power surge (I have a surge protector too) somewhere, then I don't understand how!
My PSU was recently replaced as my old one was faulty, and caused untold problems, but the HD was fine with the new one for a while!
Also I wont know if I don't try and replace it..
Do I need exactly the same PCB and what else do I need to do.. all I want is the data off the HD!
PostPosted: March 3rd, 2008, 18:19
as i knew u pepe. professional
PostPosted: March 7th, 2008, 13:16
Does anyone have one of these drives or a PCB I can purchase?
The info on the drive is
Model: WD2000JD-00GB0
Date: 22 Jan 2004
DCM: HSBHCVJAA
Thanks in advance
PostPosted: March 7th, 2008, 15:55
Hi ,
It Would Be Wise If You Could Check The Preamp and See If It is Toased Too ,Cos if it is it will toast the new pcb too
