 Post subject: PCB Replacement
PostPosted: March 3rd, 2008, 2:08
Can I replace the PCB on a Hitachi Travelstar ic25n030atmr04-0?
 Post subject: Re: PCB Replacement
PostPosted: March 3rd, 2008, 2:12
Yes, if you also swap the small 8 PIN EEPROM IC. No if you don't.
http://www.datasaversllc.com
PostPosted: March 3rd, 2008, 14:06
Which numbers on the PCB sticker HAVE to match?
08K2771
H69401B
NzG418
C9FL
PostPosted: March 3rd, 2008, 14:26
The two first lines:
08K2771
H69401B
Regards/ Bosse
http://www.rescue-it.se
PostPosted: March 4th, 2008, 0:18
Why does the 2nd line (firmware version) have to match if im removing the original nvram and soldering it onto the donor PCB?
PostPosted: March 4th, 2008, 10:59
If you match those 2 lines, it should be ok not to replace nvram chip, but there is still a chance that Nvram won't match.
www.datarecoveryne.com
PostPosted: March 5th, 2008, 5:38
Even with 2 lines the same, hitachi have a lot of different firmware versions, so you have to try it.
Users browsing this forum: No registered users and 247 guests
