 Post subject: Seagate ST320410A Firmware Question
PostPosted: February 27th, 2008, 22:02
ok here goes I have a ST320410A 20 gb with a bad control board ,( firmware 3.34),and i have another one that is dead with a good control board (firmware 3.39) could i , and if i can ,how do i install the 3.34 firmware on to the 3.39 board.
 Post subject: Re: Seagate ST320410A Firmware Question
PostPosted: February 28th, 2008, 2:36
Hi
I really had to dig deeply in my inventory to check this model, so a picture of the 2 PCBs would help to decide what to do here. If the board topology (processor type, motor Combo, reading channel IC) matches, u can change flash ROM ICs.
PostPosted: February 28th, 2008, 9:40
Dear : Pepe
It is true
processor type : ST 100167669; motor Combo : SMOOTH 100143434; flash ROM ICs : Windbond W49L102Q-70; reading channel IC : NEC SINGAPORE C2164GC
PostPosted: February 28th, 2008, 16:20
As i mentioned if everything matches, u can replace the ROM from the burnt board to the good one (provided it is intact of course :) )
PostPosted: February 29th, 2008, 16:12
Hi!
I have a board for your drive.
www.datarecoveryne.com
PostPosted: March 2nd, 2008, 17:27
I need one advice for one situation.
I have one hdd ST94019A FW:3.05 SN:3kw3zyy3 which need to be changed the MHA and from 2 months I try to find one fully compatible HDD for changing MHA but all I find was just hdd ST94019A with firmware 3.07 , 3.04, 3.07 but not 3.05. :)
What I can do in this situation ?
PostPosted: March 3rd, 2008, 4:41
3.04 or 3.07 will probably also work.
Dobre
Murphy was an optimist
PostPosted: March 3rd, 2008, 14:43
We will see if it works after I will change the MHA.
I hope this will not broke my good heads.
PostPosted: March 9th, 2008, 8:58
if everything matches like pepe said u can also write atrom using u6dle to 3.39 pcb to make it 3.34 .
PostPosted: January 18th, 2010, 7:58
Hi all!
I have a ST320410A 20 gb with a bad control board ,( firmware 3.60).How do i install firmware on to the my HDD board?
thanks!
PostPosted: January 20th, 2010, 15:51
Change the Rom chip because rewriting the firmware require special tools .
Users browsing this forum: Bing [Bot] and 186 guests
