 Post subject: Salvation Product
PostPosted: February 19th, 2008, 10:40
Hi guys, i am sadiq i have Salvation Product and have to discuss,any one interested PM sadiq005@rediffmail.com Msn contact.
Thanks.
 Post subject: Re: Salvation Product
PostPosted: February 21st, 2008, 2:23
hi,buddy,take a look here and then talk about your question
http://salvationdata.com
i will answer you if i knew
PostPosted: February 22nd, 2008, 2:20
Hi i Have Seagate U 10 Series Hard drive 10.2 GB.which has bad sector,,,before i have bad sectors after 18000GB.and i purchased the product SalvationData i selfscan add to p list and zerofill the drive ,now i am getting bad sectors in 5GB.i tried many times to repair bad sectors .zerofill and selfscan.any solution for this?
Thanks.
PostPosted: February 26th, 2008, 15:46
maybe bad head , identify the bad head and disable it .
PostPosted: February 29th, 2008, 5:11
Hi Assalamwalaikum Rameez can you please tell me how to identify and disable.
Thanks.
PostPosted: March 4th, 2008, 7:21
Hi Rameez,
I'm also a new owner of Salvation Data products like Sadiq005.
Si, could you please tell us how to identify and disable the faulty heads using Salvation Data products.
Thanks in advance.
-RDS.
PostPosted: March 4th, 2008, 10:51
Guys ,
you Said That you Also Selfscaned ,Can You Tell Us The Procedure you adopted
PostPosted: March 7th, 2008, 3:15
ragasolution are you from india. i am finding very difficult to repair.
Thanks.
PostPosted: March 7th, 2008, 16:05
Hi ,
No One can use salvation by reading salvation manuals .Guys You have to know the basics .
:ddown:
PostPosted: March 9th, 2008, 9:25
you can use terminal command to perform surface scanning using the heads one by one if there are errors on all heads then there is damage on platters and if any of the one head gives error disable that head .
PostPosted: March 10th, 2008, 3:11
sorry Rameez as of now my hdd is not working it has Klicking noise.
