 Post subject: seagate barracuda drive just clicks away
PostPosted: March 13th, 2008, 2:07
ok done a pcb swap and the hard drive does a slient click click then stops
tried the pcb board on a known good working hard drive and both boards work fine.
i think its the controller amp head chip that has gone doh
which is the next option to go with
any advice on this guys
barracuda 7200.7
model st3160023a
firmware 8.01
 Post subject: Re: seagate barracuda drive just clicks away
PostPosted: March 14th, 2008, 21:34
You should start with terminal start-up log on Seagates...
But in your case it seems like a heads problem.
Users browsing this forum: Google [Bot] and 60 guests
