 Post subject: WD1600JS-00MHB1 --- Help !
PostPosted: March 20th, 2008, 10:35
HDD with the burnt pcb:
WD1600JS-00MHB1
pcb: 2060-701335-005 REV A (with 88i6545-TF1)
fw: 10.02E01
I found these two good pcb's from:
WD2000JS-00MHB0
pcb: 2060-701335-003 REV B (with 88i6545-TF1)
fw: 02.01C03
WD1600JS-00NCB2
pcb: 2060-701335-005 REV A (with 88i6889-TF1)
fw: 10.02E03
I have changed the ROM U12 in both good pcbs
and hdd is not working
after few clicking go to safe mode and
after
WD .......HAWK
give:
10.02E02 ( firmware revision )
THIS is the reason that i suppose that the ROM is ok
but I am not shure that the PCB's are fully compatible...
Does anybody have any suggestion ?
Spasavanje podataka
 Post subject: Re: WD1600JS-00MHB1 --- Help !
PostPosted: March 20th, 2008, 12:27
Preamp is probably dead too
PostPosted: March 20th, 2008, 14:29
I am affraid that....
But what is about compatibility between these pcb' s?
Any experience ?
Spasavanje podataka
PostPosted: March 20th, 2008, 15:48
PCB are comatable if you using original ROM
PostPosted: March 21st, 2008, 4:39
Yes , I am using original ROM....
PCBs:
and
look like same
but are they fully compatibley
and I suppose that if i put original ROM
is it changed FW revision?
Spasavanje podataka
PostPosted: March 22nd, 2008, 0:34
Yes, they are
indeed
Users browsing this forum: Majestic-12 [Bot] and 53 guests
