 Post subject: Seagate ST380011A jumped straight to F>
PostPosted: March 26th, 2008, 20:44
I have a Seagate ST380011A, stays "BSY" with terminal "Error Reading Reserve track"
I exchanged the head and now i got a message
"Application code incompatible with serial flash code"
Any ideas what is wrong guys? Thank you.
 Post subject: Re: Seagate ST380011A jumped straight to F>
PostPosted: March 26th, 2008, 23:37
Did u tried to change the PCB.
DF :)
DF :)
www.datatracksystem.net
PostPosted: March 27th, 2008, 0:41
yes, it wont work, i'm having a headache now :D I suspect the head is not compatible with the pcb.
PostPosted: March 27th, 2008, 1:34
what did u matched while changing head. I have seen few time that we have to match Config also in this particular model. Mostly it is Compatible. but some time u need to match + FW and Site Code.
DF :)
DF :)
PostPosted: March 27th, 2008, 2:42
thats correct DF, I matched Config code, site code and FW and now working but not smooth lots of bad sectors, but at least it is working.
Thank's for the feedbacks.
PostPosted: March 27th, 2008, 10:23
Hello friend
Try to read ROM from u patient HDD and program again on a Donnor PCB that´s App code on cylinder´s its not matching App Code on Serial ROM
Best Regards
PostPosted: March 27th, 2008, 11:41
If i am correct this model does not have ROM.
DF :)
DF :)
PostPosted: March 27th, 2008, 21:03
yes you're right DF :D
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 95 guests
