 Post subject: Click Of Death, how to fix that problem....
PostPosted: April 3rd, 2008, 11:11
hi
guys recently i have a problem with my harddisk (western digital 500 GB internal)...
it give sound when i turn it on(the computer start)... it gives a sound of Click Click Click"" 3times, and then it turn off... it won't work. and i have many folders and files on it...
guys i really need to access to that hard drive... i heared and i read over the net that this thing called "Click Of Death"... that's ok if the drive will not work, but i hope that there is a way to recover the data from the drive...
i'm waiting for an answer....
thanx for ur helps
 Post subject: Re: Click Of Death, how to fix that problem....
PostPosted: April 3rd, 2008, 11:25
Your WD drive could have a bad logic board, or more likely, mechanical failure such as bad heads.
It needs the services of a pro to recover and if it is not the logic board, it will not be cheap. Typical range for this repair is $1500 - 2500.
Jon
http://www.datasaversllc.com
PostPosted: April 3rd, 2008, 14:20
When disk spins up, clicks few time and then powers down, it is sign of failed preamp ar heads.
This type of repair considered to be very difficult even for a pro.
I would suggest to do a research, and determine a reliable firm which will not overcharge you for a service.
I am sure you can find a DR specialist on this forum for your needs.
www.datarecoveryne.com
PostPosted: April 4th, 2008, 9:34
We could do that if there is no media damage
Users browsing this forum: No registered users and 234 guests
