 Post subject: WESTERN DIGITAL WD 1200 CAVIAR
PostPosted: April 15th, 2008, 3:44
I have the following disk which after a power surge does not power on at all all it does is the pcb board gets hot when power is applied to it.
MDL:1200JB-00DUA0
DATE: 16 NOV 2002
DCM: HSBHNAJCH
S/N: WMACK1251478
Can i replace the pcb with this one
MDL:1200JB-00DUA3
DATE: 09 JUL 2003
DCM: HSBHCA2AH
S/N: WMACKM2002448
 Post subject: Re: WESTERN DIGITAL WD 1200 CAVIAR
PostPosted: April 15th, 2008, 4:24
You can, but you'll have to replace the eeprom chip also.
Dobre
Murphy was an optimist
PostPosted: April 15th, 2008, 5:00
which one is the eprom chip ?
PostPosted: April 15th, 2008, 5:09
and why does it have to be replaced. What will happen if i dont.
PostPosted: April 15th, 2008, 5:16
Its an 8-pin chip on the pcb. Marking like 25P... If you dont replace it the drive will click and you wont be able to access the data.
Dobre
PostPosted: April 15th, 2008, 6:01
How do i know if the 8-pin chip from the bad pcb is working so that i put it in the working pcb?
Can this be done without unsoldering and soldering
PostPosted: April 15th, 2008, 8:14
I never had a defective one. You can use an ohm-meter to measure the impedance between the supply voltages and the signallines. If there are no shorts it should be ok.
Dobre
PostPosted: April 15th, 2008, 9:08
Agree,
in my experience, also with drives with badly burned PCBs or at least combo chips not a single flash chip has suffered so far. It may be possible, but the only way to check is to solder it to the donor PCB and give it a try.
PostPosted: April 16th, 2008, 3:07
do you need a special hot air gun for soldering-desoldering or can be done with simple soldering iron?
PostPosted: April 16th, 2008, 3:32
8 pin can be done with a soldering iron if you know what you're doing. If you don't, you can ruin the PCB with either tool.
Blob solder across all pins on one side, and then the other very quickly. Slide chip off and remove excess solder.
PostPosted: April 16th, 2008, 4:39
Dobre
Are u sure that this series of pcb have prom U12?
Spasavanje podataka
PostPosted: April 16th, 2008, 4:57
Yes, i have such a disk in my hand at this very moment. :D
Dobre
PostPosted: April 16th, 2008, 5:37
Dobre
ok...
what is the code of PCB ?
2060-xxxxxx-xxx ?
Spasavanje podataka
PostPosted: April 16th, 2008, 5:59
2060-001173-004
Dobre
PostPosted: April 16th, 2008, 6:26
dobrevjetser wrote:
2060-001173-004
Dobre
Tnxs
Spasavanje podataka
PostPosted: April 16th, 2008, 9:10
If you are going to use that PCB you need to resoder the chip
Otherwise it will not work
Those PCBs are from different drive families
PostPosted: April 17th, 2008, 4:45
mine is 2061-001160-100b
PostPosted: April 18th, 2008, 16:05
so if you have
exact match in the board number 2061-001160-100b and here WD1200JB-00DUA0 then do you still have to swapp the rom chip?
I changed only the pcb and the drive came alive it clicks it reports a size of 8,4 gb but is not accessible
PostPosted: April 18th, 2008, 19:11
I made the experience that it never worked for me without swapping the flash ROM.
Users browsing this forum: No registered users and 271 guests
