 Post subject: Hitachi HTS541...
PostPosted: April 17th, 2008, 23:37
Does anyone know if this model has adaptive data on the ROM chip? I have a dead drive(no spin) and a PCB match but not sure if I need to move the ROM. If so, which chip is it? U6?
Thanks!
A
 Post subject: Re: Hitachi HTS541...
PostPosted: April 18th, 2008, 0:04
Please give the entire model no. of the drive. In any case you need to move the ROM chip.
PostPosted: April 18th, 2008, 0:28
ROb,
The model is: HTS541060G9AT00
Thanks,
A
PostPosted: April 18th, 2008, 9:05
You need to move ROM and NVRAM (two chips)
If ROM is inside CPU you will need to find PCB with the same ROM revision
If you just swap PCB - it will not work
PostPosted: April 18th, 2008, 9:32
Hi A,
You can change the NVRAM from this PCB into another working PCB and your drive will work.
If it doesn't let me know.
Before that check the fuse of the pcb in power section.
PostPosted: April 18th, 2008, 9:58
Thanks ROb. As you know, I meant NVRAM, not ROM :)
A
PostPosted: April 20th, 2008, 9:45
Doomer,
Thanks for the response. Which chips are ROM and NVRAM? DO you have a diagram or chip IDs? Thanks for your help.
A
PostPosted: April 20th, 2008, 13:16
U3 - ROM chip
U6 - NVRAM chip
Mikippp
PostPosted: April 20th, 2008, 17:24
Thanks Mikipp!
Users browsing this forum: No registered users and 91 guests
