 Post subject: Playing with Seagate
PostPosted: April 21st, 2008, 11:21
I wonder if anyone has had success "converting" a SATA Seagate 3.5" drive to an ATA (or visa versa)?
Jon
http://www.datasaversllc.com
 Post subject: Re: Playing with Seagate
PostPosted: April 21st, 2008, 13:24
you mean changing the pcb's ?
I know for sure you can use the heads of a pata disk for a sata disk and vice versa. Just take care about the normal requirements for a head donor.
So changing the pcb's should work also.
Dobre
Murphy was an optimist
PostPosted: April 21st, 2008, 13:31
I am not that sure :)
maybe after writing correct Appcode.
PostPosted: April 21st, 2008, 22:00
Jon
What you mean, Jon?
what is the Coverting process?
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: April 21st, 2008, 23:26
Laura,
What I mean is swapping a SATA logic board onto an ATA drive (or visa versa) and making the new hybrid work.
Jon
PostPosted: April 22nd, 2008, 4:15
it works on Maxtor DM+9:
you can put pata pcb on sata hdd - and work...
vice versa - not work ...
but it is very rare situation....
Spasavanje podataka
PostPosted: April 22nd, 2008, 5:57
maybe can be done when there is a sata bridge attached to sata PCB.
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 22nd, 2008, 7:50
Spasavanje podataka
PostPosted: April 22nd, 2008, 15:57
Also works in marvell drives but for saeagate i dont think it would work .
PostPosted: April 22nd, 2008, 18:20
According to my experience:
It only works on <128GB drives, since if U put a PATA board onto a SATA drive, there will be no LBA48 support.
Also the drive won't work in UDMA mode, but in MWDMA only.
But if U write a compatible ATA overlay onto the SATA drive, it will solve these problems above.
PostPosted: April 23rd, 2008, 4:01
I have success "converting" a SATA Seagate 3.5" drive to an ATA on Seagate B 7
Users browsing this forum: No registered users and 47 guests
